02 / gasket question
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
Just got the manifolds all unbolted and have a couple q's.
How'd you remove the 02 sensor, and how do you extend the wire?
Did your manifolds have gaskets on them? i cant seem to find a gasket between the manifold and cylender head. Its weird, especially b/c the gaskets hooker gave me are like .25 inch thick.
-chuck
-chuck
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
get a piece of pipe and put in on the opposite end of the wrench. should do the trick. dont spray pb blaster or anything, it will harm the sensor. no gaskets were used from the factory
Car: 89 RS
Engine: lo3
Any one know the best way to extend that wire though? Do i just cut it and solder a longer piece in the middle of it?
-chuck
BTW, how likely is it that blaster will harm the o2 sensor, the way i spray that stuff around it's very likely that a good amount of it got on there.
-chuck
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
-chuck
-chuck
Transmission: 4L80E/4L80E
A while back somebody had a link to O2 sensor wire extensions that had the proper connector on each end. Try a search (use "O2*" in the text search line since "O2" is too short).
Car: 91RS
Engine: 305tbi
15/16 I think, definatly not 1in
Mine came out with almost no effort.
You can buy an o2 sensor socket if your in a shopping mood.
O2 sensor is 15/16". Get the O2 sensor socket, it has a slot for the pigtail to hang loose. It's tight for a wrench to get up for the stock manifolds, and much easier with a ratchet and a long extension.
For extending the wires, check the header companies...from Hedman...
Replacement Oxygen Sensor Wires & Plug
Part # Description
24018 18" single wire oxygen sensor wire. (GM)
24036 36" single wire oxygen sensor wire. (GM)
24050 Oxygen sensor plug for those vehicles where sensor is not required. 18mm.
24050 is the O2 sensor bung.
Other companies should have other parts. You could also piece it together from pigtails found at NAPA.
Part # Description
1992 Trans Am
May 10, 2023 07:19 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
