Got my headers, may have problems??
Old Mar 22, 2004 | 06:05 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Ok I got my headers from ACS, they look beautiful!
Heres my problem:
On one header If I blow at the top of the air tubes, some blow very well (Can feel it on your finger if you stick it in the header tubes) and some dont very well at all, is this a problem?
Here is my biggest worry, my other header rattles when I move it, and I cannot get whatever is rattling out. I think it might be in one of the air tubes. Also on that header 2 air tubes blow absolutely no air, they are definetly plugged
I recorded a sound wav of the sound:
Header rattle
Any input would be appreciated!
Old Mar 22, 2004 | 06:08 PM
25THRSS's Avatar
Sounds like the coating clogged the tubes up. As for the rattle I wouldn't worry about it. It'll prolly be pushed out when you first start the car.
Old Mar 22, 2004 | 06:13 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Is it ok to run on my car?
And go into my cat?
Old Mar 22, 2004 | 06:43 PM
91Z28-350's Avatar
Use some flexible piece of wire or plastic, jam it in the air tubes to dislodge whatever is rattling. On my headers (coated by Jet-Hot) there were some beads in there. It sounded exactly the same.
Old Mar 22, 2004 | 07:04 PM
25THRSS's Avatar
And go into my cat?
It should be fine, and just start it without the cat.
Old Mar 22, 2004 | 09:06 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Thanks you very much for the replies guys. I looked in there with a light and see one tube plugged with what appears to be a white bead.
Anyway.......................
Old Mar 23, 2004 | 05:09 AM
CGCBandit's Avatar
Wow, those look real nice! Did you order them with air? How much were they if you don't mind me asking?:lala:
Old Mar 23, 2004 | 10:53 AM
Car: 1988 IROC-Z
Engine: 427 SBC
Total with shipping came out to $546
Old Mar 23, 2004 | 04:33 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I got mine from ACS also. Mine are the 2055's. Which ones are they?
Street Lethal
Apr 30, 2019 12:14 PM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
