AC and Alternator brackets
Old Mar 30, 2004 | 07:50 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
How necessary are they?
I cant figure out how to modify these brackets to get them to fit with my 2055's. do i even need to put them back on? the accessories seem to be pretty sturdy with out them.
-chuck
Old Mar 30, 2004 | 08:25 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
I am very curious also? About to install my 2055s and was wondering if I needed to alter the OE ones or just buy the ones from summit...What do you guys think?
Old Mar 30, 2004 | 09:35 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
do you have the link for the ones from summet. didnt know they even had em.
-chuck
Old Mar 30, 2004 | 09:51 PM
MikeS's Avatar
I don't know if you've got the same brackets that I have, but I've always been able to use the stock ones. The only trick was to modify the AC bracket. I guess I should note that all of my cars have used driver's side AC compressor mounting. When you look at the bracket from standing by the driver's side fender, it makes sort of an "A" shape. When you hold it in place, one of the legs of the A hits a header tube. Cut this leg off.
Old Mar 30, 2004 | 10:12 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
nope, must be different. My AC is on passenger side, and Alternator is on drivers side.
-chuck
Old Mar 30, 2004 | 10:46 PM
davehamilton's Avatar
Alot of people opt to modify theirs and then send them to us to coat and polish. Anything custom and polished helps, and $10 per bracket is a nominal fee to have more shine under the hood!!!
A drill and a grinder can work money saving wonders!!!
Old Mar 30, 2004 | 11:19 PM
25THRSS's Avatar
I doubt you need them
Old Mar 31, 2004 | 09:56 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
i threw mine away
Old Mar 31, 2004 | 01:12 PM
Here is that link you asked for
http://store.summitracing.com/defaul...ooker+brackets
Old Mar 31, 2004 | 01:20 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
If you decide not to use them, send them to me. I need them for my car. I did the serpentine conversion on my 87 and I WANT them on there. I don't think they are necessary (I've been driving around for a while like that now), but I still want them.
Old Mar 31, 2004 | 09:33 PM
matlock's Avatar
Car: 89 GTA
I'm also awaiting my 2055's and have my manifolds removed. What you guys are describing about the passenger-side AC bracket doesnt sound like mine. Mine is just a single pipe going from the AC compressor to the 3rd bolt from the front.
Passenger side:
Drivers side:
I'm doubting that I will be able to use the AC bracket on the passenger side. Should I try to find a different style bracket and remove the leg of that one?
Old Mar 31, 2004 | 11:00 PM
Hummm...no clue. I have an L69 maybe thats why they are different. Someout there must know but its not me..
Old Apr 3, 2004 | 07:24 AM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
I started my car up the other day w/o the brackets on, nothing flew off or broke or anything horrible like that.
After analyzing things a little closer, i dont even see what the AC bracket does. I've taken a few physics courses, and the only force on the compressor is being applied by the belt. When the belt is in motion i dont believe it applies any greater force. Not that this matters anyway since the compressor bracket is only offering support front to back, and the force is being applied left to right. (while looking at the motor head on) Now the altenator bracket, since it is on the same plane as the applied force will actually offer support. but since there is know extra force when the belt is in motion, and they (the accessories) seem to have no trouble staying up with out the brackets, i dont believe the brackets are necessary and have decided to run with out them.
If anyone sees any flaws in my basic physics knowlege please share, im still learning.
-chuck
Old Apr 3, 2004 | 07:25 AM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
BTW, matlock, i have the same set up as you. (bracket wise)
Old Apr 3, 2004 | 09:14 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
After installing my headers I've run my AC compressor & alternator without those back brackets for a couple of years with no problems yet.(knock on wood!)
Old Apr 6, 2004 | 07:55 PM
91Z28-350's Avatar
Re: AC and Alternator brackets
Use the stock manifold studs with spacers. That's what most people do.
Old Apr 7, 2004 | 10:23 AM
25THRSS's Avatar
I talked to Hooker directly about the brackets, and this is what they said.
"Those are just vibration braces. you probably will notice a little more engine vibration when the AC is on."
Otherwise, removing them is just fine. It'll eliminate even more clutter under the hood as well.
Old Apr 7, 2004 | 01:29 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Makes perfect sence then, i knew they couldnt be offering much support.
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
armybyrd
Sep 26, 2015 03:37 PM
