Hooker LT's
Old Apr 2, 2004 | 04:12 PM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Hooker LT's
OK I just ordered my 2210's from Jet Hot but I have a few questions. I have read all the sticky's and Traxion's write up on istallation but i need a little more help here.
1-They said they do not come with the reducers...Where should I look to get them?? Is Jegs or Summit the best route?
2-Is there a place allready on the driver side for teh knock sensor to be moved to? I looked and could not see anything.
3- I have read that you dont want to have new coated headers on a engine during break in time...is this true?
I know allot of questions, I have been in Iraq for a year and I am trying to do allot of catching up. Thanks for any help.
Rocc
Old Apr 2, 2004 | 06:31 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
1) You can buy collector reducers in just about any parts store
2) Couldnt help ya there
3) Thats the second time on here I've read that ...its BS. Why would a motor thats being broken in operate any differently than a old raggity motor?
also better make sure you gotta a mini-starter and a grinder.
Old Apr 3, 2004 | 07:29 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
Just my own take on the Hooker Lt's just so you know I had to absolutely no grinding at all to my car to get them to fit. SO not everyone needs them.
On the drivers side there will be a little plug in the block right above the oil pan. Careful they tend to stripJust pop that out and put that on the other side and put the knock sensor in the drivers side. Be ready for antifreeze though as both teh knock sensor and the plug are drain plugs for the block so you WILL get antifreeze. I suggest you drain the radiator as much as you can first then do the block drains. Good Luck.
Old Apr 4, 2004 | 09:27 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Thanks alot, I didnt know that. I will be draining th engine anyways here in a few days so I will do it then.
Old Apr 9, 2004 | 11:28 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Sorry guys, but there is a break in period for a new cam and lifters, and the headers will absolutely glow red when you run in the new cam for about the first 3 minutes of running. I'm not sure if this is true of roller cams, I've never broken one in before, but it will toast any coating you have on your headers. Anybody know if roller cams do or do not glow when breaking in?
Troy
So Cal
Old Apr 10, 2004 | 03:10 PM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Yeah I would like to know about this also. I have never heard of that, but then again all I have really delt with is Hyd roller cams. If someone could shed some llight on this....thanks
Old Apr 10, 2004 | 08:13 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Roller cams don't require break in
Old Apr 10, 2004 | 08:40 PM
Car: '89 IROC-Z
Your headers should NEVER glow red ANYTIME even during breakin. If they do your timing is probably waaay off. And yes, roller cams do not require a break-in because there is nothing to break in ...No non-moving parts are touching each other.
Old Apr 10, 2004 | 10:25 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
The cam is barely working any harder during break-in and your headers should NEVER glow-red.
Old Apr 11, 2004 | 11:19 AM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Sounds good, thanks...
no green
Jan 9, 2016 09:22 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
