what size is stock intermediate pipe?
Old Apr 7, 2004 | 07:07 PM
Jeffrey Fontaine's Avatar
Car: 1992 Z/28
Axle/Gears: 2.73's I think
I have a 92 Z/28 with TPI 305, F code motor. It has the single exhaust. I need to know what size so I can order my Edelbrock exhaust.
Thanks,
Old Apr 7, 2004 | 10:59 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: what size is stock intermediate pipe?
Thanks,
You should be able to order by engine code or type. All of the edelbrock kits are 3" but it will have the necessary reducer to attach to your cat. I belive your stock I pipe is 2.5" for reference.
Old Apr 7, 2004 | 11:44 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Engine code F has a 2 3/4" intermediate pipe. But most aftermarket replacements are 3" as mentioned, which bolt right up to your stock cat without any adjustments.
Old Apr 8, 2004 | 07:38 AM
Car: 1992 Z/28
See, the confusion is everywhere From my circumference measurements divided by pie, it looks like I have the 2.5", but who knows if it was swapped etc. By engine code, it should be 2.75 according to Edelbrock, but I can't get a direct answer. I looked at the intermediate pipe and it looks like the donut on the edelbrock I-pipe is bigger than the replacement cat I got from Autozone. I guess its possible their part is universal between the engine codes, wouldn't be the first time. Arghh, can't wait too much longer, the muffler and tailpipes fell off the car last nigh while my fiance was driving. Hmm, could I measure that pipe (right before it would go into muffler) and assume its the same diameter as where it would come out of the cat?
Thanks a bunch!
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Bstrang6
Aug 26, 2015 11:39 AM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
