will strait pipes mess up my piston rings?
Car: 1985 Firebird/T-tops
Engine: 5.7 V8 350
Transmission: 5-speed
some one that i was talking to said that if you dont have a muffler on then it doesnt create enough back pressure and your rings need that but another person said it doesnt really matter so what do you think
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: will strait pipes mess up my piston rings?
Car: 93 S10 blazer
here is the way all that was explained to me. Running open headers on a race car does not damage anything in the motor while it is running. It is after the car is shut down that creates the problem. The short amount of pipe from the motor to the end of the header can cause a very rapid cooling of hot engine heads because fresh cool air can blow right up in there. This extremely rapid cooldown with the rest of the engine hot is what damages things causes stuff to warp. As long as you plug the headers after a drive or race everythig should be ok. Once again that is the way a really smart dude explained it to me. It made a lot of since beacause the shorter the exhaust the more heat should be able to escape the motor while the car is on.
P.S. Straight pipes are the loudest most annoying thing I have ever done to my car. I am only 21 years old and I already feel like Im too old for that noise.
Car: '90 RS
Engine: 377 LSX
Car: 87 iroc
Engine: L98 350
So wait a second, I'm confused. This situation you're talking about, is this only when your exhaust dumps directly after the headers??? You said you should plug it up after usage, like with a towel or something? So if i have a cutout right after my headers I should close it before I turn off the car I guess huh?
Car: '90 RS
Engine: 377 LSX
Car: 93 S10 blazer
I agree. It is always a good idea to close the cutout. that thing I said earlier is only a possibility its not to say every car with open headers or cutout/dumps will have damaged exhaust valves. It is just a precautionary measure if you have very short exhaust like just headers and nothing else. Rapid cooling of one part of the engine when the rest is still hot is just never a good Idea. Also normal driving with a cutout is different than a 10 sec pass with open headers right before shutting down.
Hope I didnt scare anyone.
P.S. I have no idea what to plug a hot header with. Perhaps a shop towel. ha ha
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
Originally posted by 25THRSS
I ran my car with only a y pipe and nothing attached after it for a few months with no ill effects.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I know this debate went for about 3 pages once, but I think the message got lost in the bickering. You must have backpressure to run a n/a car, IF you want to make top end power . Without backpressure, the lack of exhaust flow will kill low end torque.
A turbo car on the other hand, needs none at all. The more you uncap it, the more power you make throughout the rpms.
By this I'm talking about open headers, not a mufflerless exhaust.
Car: '90 RS
Engine: 377 LSX
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
its a veloctiy vs pipe size thing.... NOT backpressure.
and if you have headers on a car, that is MORE then long enough to make up for any "cooling warping" of the head/valves.. even shorty headers.... or manifolds... or blockhuggers...
dimented24x7
Sep 17, 2015 06:58 AM
