tubing adapter
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
tubing adapter
I have a lg4. I have a carsound 3 inch cat and a pacesetter 3 inch catback system. I'm saving money for the 2055's. Can I use a tubing adapter with a 2 inch outlet and 3 inch inlet. Is this the correct size. Will it be hard to undo?
Transmission: 4L80E/4L80E
2-1/4" -> 3" would be better.
Install the cat & cat-back where they belong. If you then cut the existing y-pipe, put the adapter in and clamp the adapter to the cat inlet, it won't be too hard to remove when you get the proper headers & y-pipe.
gixxer92
May 18, 2017 11:20 AM
no green
Jan 9, 2016 09:22 PM
