Lt headers and fuel line. How close is yours?
Old Apr 29, 2004 | 11:18 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I swapped in a set of LT hedman headers with s-tubes. The exhaust seems to be 1 - 1/12 inches away from the fuel lines at the closest point. Could this cause a problem?
I ran the drivers side pipe under the trans crossmember to the pass side, then the two 2 1/2 in pipes follow the driveshaft to the rear. I have two dynomax bullit mufflers with turndowns just before the rear.
Should I install a heat shield on the stock fuel line? How close is everyones headers to the fuel line?
Old Apr 29, 2004 | 02:48 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
while a heat shield or sleave will never hurt, 1.5" is fine...
even more so if you have a return style fuel system.
Old Apr 30, 2004 | 09:51 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Yeah, I am running the stock fuel lines with the return. How close would be too close? I was just guessing on the distance. Might even be 3/4 inch.
thanks
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
mdtoren
Aug 23, 2015 12:52 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
