high-flow catco?
Old Apr 29, 2004 | 02:00 PM
Farfire70's Avatar
high-flow catco?
Are all universal Catco cats considered to be hihg-flow or does it have to say hihg-flow specifically becuse all i see on summit are universal and direct and I'm planning on getting teh universal if it is a high-flow.
Old Apr 29, 2004 | 02:53 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Spend the few extra dollars and get the direct fit Catco ( 3" in & out) and save yourself some problems about making it fit your car. Not a lot of room under there to play with. My opinion.
Old Apr 29, 2004 | 03:11 PM
Marc 85Z28's Avatar
All Catco converters are considered high flow. I've got a 3" universal, and noticed no performance or sound improvement with a straight pipe, so the converter went back on.
Old Apr 30, 2004 | 09:24 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I agree...direct fit .
Ed
Old May 1, 2004 | 06:07 PM
badCHEVELLEman's Avatar
Car: chevelle + camaro
Engine: 520hp 350 350
Transmission: th 350 700r4
Axle/Gears: 4:56 3:23
i bought the daul cat direct fits from catco with a flowmaster system and had to cut up the direct fits anyway to use the flowmater y pipe. just get the right dimentions and have a shop weld them up
Old May 2, 2004 | 09:37 PM
Farfire70's Avatar
Is the direct fit a little shorter than the universal to provide more ground clearance?
Old May 3, 2004 | 09:18 AM
Marc 85Z28's Avatar
Ground clearance has nothing to do with it. Longer or shorter, it would affect fitment into the exhaust, and not exhaust ground clearance. The universal can be shorter than the direct fit. They make the universal fit converter in several different lengths. But most are shorter than the direct fit.
Old May 3, 2004 | 09:48 AM
DJP87Z28's Avatar
Installed the direct Ct-9118 Between my SLP headers and SLP 3"
catback exhaust with no problems, did use the SLP slip fit concector from the headers. When I installed my SFC's I did have to remove the heat shield from the Catco for clearance, but you may have to do the same with other cats. The Direct fit is the way to go.
johns84bird
Aftermarket Product Review
30
Apr 18, 2005 12:48 AM
johns84bird
31
Feb 13, 2002 11:23 AM
Dan87IROC-Z
Sep 19, 2001 07:38 PM
Dan87IROC-Z
Aug 20, 2001 10:49 AM
