Sound files
Old May 1, 2004 | 07:35 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Sound files
Im working on a little driving game for a school project, I made some sound bytes to use, figured everyone would like to listen, if anyone has any good audio of racing it will be cool if you would post a link the them. You will need win zip to uncompress the file.
http://www.westga.edu/~stu53821/firebird/sounds.zip
Old May 5, 2004 | 09:32 PM
DanRS's Avatar
Car: 89 Camaro RS
Engine: LO3 305 TBI
Transmission: T5WC
Sorry to be off topic, but I recommend IZarc (at http://www.izsoft.dir.bg/ ) over Winzip. It's better and free....
Old May 6, 2004 | 12:09 AM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
sounds mean man! what make yours crack up though?? whats your exhaust setup?? u have headers? carb or FI?
Old May 6, 2004 | 12:21 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
my cat had started falling apart internally last year and I took it off and put a peice of exhaust pipe in place of it, ever since then it has cracked up during the idle down. Other than that it is just a factory replacement style muffler and pipes. I do have a air leak at the exhaust manifold though, One of the studs is broken and I havent had time to fix it. So I imagine the air leak and the fact it it running a little rich is what you here. Other than that its a stock 305 with tbi. It has 190k on it also, but uses no oil and has no leaks, except the pan is starting to leak a little.
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
