edelbrock 3 in cat back???
Old May 8, 2004 | 11:45 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
has anyone had any expierience with this exhaust i have edelbrock headers and a 3 inch cheap muffler shop exhaust now but when i lowered my car the exhaust was smashed by the axle comming up to it. would anyone possibly know if this system will allow a good enough clearance to not be ruined if i hit a decent bump. i already have a flowmaster 3 in on my 85 trans am and it sounds awesome would this sound similar to the edelbrock exhaust or should i jsut get flowmaster and save the cash
Old May 9, 2004 | 03:08 PM
Coop91SRS's Avatar
Car: 1991 Camaro RS
Transmission: 5-SPD
I had the edelbrock 3in catback on my old 91.. never had any probs with the exhaust hitting on anything. Mine wasnt lowered however. My only thought is either the lowering might indeed cause a problem or the exhaust shop botched the over axle part of your exhaust causing it to hit.
Old May 9, 2004 | 08:22 PM
2out_The_Left's Avatar
i've only heard good things about the edlebrock cat back. its not even that expensive, run you mid 200 range. i think the flow master is more money then that. i was never a fan of the flow master anyhow.
for your exaust being crushed, i would say it was a faulty exaust setup, unless you have some whack springs in there (like cut coils) i steer away from lowering cars also.
Old May 9, 2004 | 10:18 PM
Engine: LO3 and LT1
no i dont use juk stuff except my exhaust i will never let that guy bend pipes for me again. and my springs are eibach and not very old so they arent sagging. summit has the edelbrock kit for 283 dollars has anyone saw it cheaper anywhere else
Old May 10, 2004 | 08:25 AM
jegs has it cheaper i believe. i never shop at summit because of the prices and the attitude i got last time i called. i'm 100% jegs shopper, unless i'm getting an OE replacement part then its dealer only.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
