hollow cat
Old Apr 30, 2004 | 10:08 AM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
hollow cat
what would be the down side of running with a hollow cat and straight pipes. I'm looking for more sound. I've got 80 series on now. But I'm not to thrilled with it.
But I also don't want to much attention from cops.
Old Apr 30, 2004 | 04:16 PM
underdave's Avatar
Car: '91 Firebird vert
Engine: 305 TBI
Transmission: auto
no muffler or cat will get LOTS of attention from cops. if you want, just keep your system and get a cutout. that way you can switch back and forth.
Old May 1, 2004 | 02:08 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Re: hollow cat
try hollowing out the cat and try that first before you run strait pipes because if you run strait pipes and hollow cat your a cop magnet....
Old May 8, 2004 | 05:27 PM
interfac9's Avatar
Car: 1999 Mustang GT
Engine: 4.6 SOHC
Transmission: T-45
Axle/Gears: 4.10
I have heard that hollowing out the cat will cause you to lose power and torque. Is that true?
Old May 8, 2004 | 11:50 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
if you don't put a pipe through it...yes it will. It will cause a lot of turbulance in the exhaust stream. Just get a high flow cat. Its smog legal, no loss of power, and a mellower sound.
Old May 9, 2004 | 05:51 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
the cat in place with the honeycomb stuff inside will cause it to have turbulance also, so hollowed cat over stock cat would be better, and create a little more horsepower and torque by letting the cat flow better, but a straight pipe in place of the cat would have more velocity over hollowed cat, its your choice on what you do.
Old May 9, 2004 | 08:32 PM
2out_The_Left's Avatar
just take the shields off an old cat and tac weld em over a piece of pipe. stright pipes will gain you torque and noise though. bends tone and exaust nicely. you will want a little back pressure if your on the street also. i had open headers on my GTA and it was a dog while accelerating. i put the exaust back on and it seemed to accel faster with it than without. after that experience, i will never run open pipes again.
Old May 9, 2004 | 10:06 PM
Sorry dude....you never want any backpressure! That is common misconseption. Read any car book that talks about exhaust or do a search on it here....all will show how the less the back pressure the better.
Old May 9, 2004 | 10:08 PM
And i do agree on the cut-out. Really good idea. You get the best of both worlds!
Old May 10, 2004 | 12:19 AM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I've got hooker headers -> high flow cat -> full flowmaster exhaust, all 3".
Was planning on taking the cat off completely after it's smogged (good for 2 years) and then putting a straight pipe (with shields to satisfy cops) still leading out to the Flows.
Will removing the cat add some power?
Anyone with a similar setup know if it sounds better or worse? Thanks!
Old May 10, 2004 | 02:56 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
i dunno dude... i believe you want a certain amount of backpressure in order not to have all low end go to crap...
Old May 10, 2004 | 05:21 AM
QuickStyle's Avatar
Car: 91 Z28
please dont let this turn into a back pressure arguement, there are many threads about back pressure. do a search
Old May 10, 2004 | 11:29 AM
rsn932's Avatar
https://www.thirdgen.org/techbb2/sho...t=backpressure
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
