What is this?
Old May 7, 2004 | 05:09 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
What is this?
Hey guys..I want to remove my passanger valve cover to change the gasket while i am doing my header swap but this is in the way. I need to remove it. What is it and is there any danger it taking it off and then puting it back on?
Old May 7, 2004 | 05:21 PM
Sgt.D's92RS's Avatar
Car: 92 RS
Engine: 305 V8 numerous Mods:
Transmission: Auto+shift Kit 3.73 gears
looks like
looks like a EGR valve to me
Old May 7, 2004 | 06:30 PM
so then there is no problem in taking it off and putting it back on? Do I need a new gasket or something?
Old May 7, 2004 | 06:35 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
yah there should be a gasket on it....since it will probably b all dried up and possibly brittle...i'd say replace it.....they are a couple bucks at your local parts store....
Old May 7, 2004 | 06:44 PM
fast86z's Avatar
Ya it is your EGR valve and you will need to put a new gasket on i think.
Old May 8, 2004 | 08:33 AM
hot69z's Avatar
Car: 1982 Z/28 H.O.
Engine: 355
Transmission: t-5
you shouldn't have to remove it to get the valve cover off tho. the EGR sits high enough on the maifold that it should not be a problem at all
Old May 8, 2004 | 09:28 AM
red90bird's Avatar
Car: 1990 Firebird
Engine: LS3
just by looking at it, I think it looks pretty old, personally I would replace both the gasket and the egr vlave. just my opinion
Old May 8, 2004 | 11:40 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
if it where me, i would take it off and leave it off, but that's just me.
Old May 8, 2004 | 11:17 PM
Thanks for the help guys...
I tried to remove it but one of the bolts is really stuck. I tried everything under the sun, but it won't budge! I need to pass emissions so would removing it not allow me to? About how much would a whole new one cost?
And how do I remove this *** damn bolt!!!
Plus I think these are aftermarket valve covers so they sit higher i guess.
Old May 9, 2004 | 02:33 AM
hot69z's Avatar
Car: 1982 Z/28 H.O.
Engine: 355
Transmission: t-5
for removin the bolt i would say a little heat never hurts hit the manifold with some cold water while applying heat to the bolt head (not too much heat tho) this will pull the manifold away from the rusty threads a bit then b4 cranking on the bolt apply a bit of nut buster on the base of the bolt to try and get a lil bit of rust killer on the treads as well
Even aftermarket valve covers should clear the damn thing it will be a pain in the *** but it should clear. from the pic they look like replacement stocks to me
Old May 9, 2004 | 08:27 PM
2out_The_Left's Avatar
if you want to pass emo, you'll need that valve and the cat. all the other stuff can go though
i wouldn't use heat around that area for the bolts. you should use a long breaker bar with a pipe at the end if its THAT hard to get off. soak it in P oil 1st. an impact driver with a socket will work also. dont forget those covers will be on there after the bolts are removed. have a pry bar or crowbar ready...
Old May 9, 2004 | 10:04 PM
They problem is that you can not get to the bolt with a socket wrench..you have to use a cresent wrench. They EGR valve itself is in the way.
Old May 10, 2004 | 08:22 AM
unbolt the valve and move it out of the way so you can hit the bolt behind it. you can remove the valve to work behind it, just make sure to put it back. i'd check and see how much a new one would cost, yours looks a bit old.
Old May 10, 2004 | 11:40 AM
yeah...sat for 6 years under a tree....thanks guys
