Stock pipe size?
Old May 18, 2004 | 11:24 PM
My Black 1991's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Transmission: 700-R4
Axle/Gears: 2.73?
Stock pipe size?
I measured my pipes and they seem to be 2 1/4 but all the sizes listed in books like Jeg's say 2 1/2 as the smallest size. Anyways, is 2 1/2 what came from the factory? Maybe thats why I not very good power is from the pipes being too small. lol BTW are K&N's really worth the money and do they show a significant difference in hp?
Old May 19, 2004 | 12:06 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
2-1/4" is what the factory used.
The small exhaust is one of your performance problems. Poor flowing heads and lame cam are right up there on the list.
Fix all those things, now you'll get to learn PROM tuning.
Old May 19, 2004 | 09:12 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Amen to that. The stock piping is garbage on TBI cars. It is really pathetic once you get it out of the car and look at it. Changing to a full 3" system will really add some umph to your car. A word of advice is to buy all of your exhayst components for a TPI car. That way they come a full 3" without any attached reducers. If you buy your exhaust a pice at a time instead of replacing it all at once you will have to buy the systems that correspond to your engine code. That way the 3" piping will have the necessary reducer to attach to your stock cat.
Old May 21, 2004 | 02:02 PM
Camaro68Vette63's Avatar
Car: 1992 Z-28 Camaro
Engine: LB9 305 TPI
Whats the stock pipe size on a LB9 TPI motor?
Old May 21, 2004 | 02:08 PM
AmorgetRS's Avatar
2 1/2 I think. It still stinks.
Old May 23, 2004 | 03:01 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
My 87 IROC-Z LB9 TPI had the 3" pipe from the Cat to the muffler and then 2 1/2" outlet pipes. Factory stock and I am the original owner. Now with A 350 TPI with SLP 1 3/4 Headers, 3" in & out Catco Cat and SLP 3" Catback system.
Old May 23, 2004 | 10:45 PM
five7kid's Avatar
3" at the cat inlet, 2-3/4" after for '86-'90.
'91-'92 single cat was the same as TBI.
Old May 24, 2004 | 01:17 AM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
thats my schedule.
Did the exhaust this winter, working on cam heads and intake next winter. hopefully learning to tune this summer. You forgot to add gears to your list. Most of the lo3 cars came w/ 2.73 opens which is just as pathetic as swirl port heads. 1250 rpm stall converter is no good either...
Do it all at once. If you start you wont want to keep going under there to work on an unfinished exhaust, oh and run it open headers at least once. sexy sexy.
-chuck
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Bstrang6
Aug 26, 2015 11:39 AM
knight72
Aug 10, 2015 09:32 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
