major black?
Car: 89 camaro
Engine: 2.8L V6
major black?
my o2 sensor has major black stuff on its tip and its only 4 weeks old. 89 2.8 camaro what is this and has it gone bad? code 44 has appeared 4 me should i change it or is it normal?
Transmission: 4L80E/4L80E
What did the old one look like? Were you getting the code before replacing it?
Car: 91 RS
Engine: vortec 355 hsr
Transmission: wct5
Axle/Gears: bg3.27
to test it un plug it, then start your car, then get a volt meter and put the positive lead on the wire coming from the sensor, and ground the negative lead.the reading should be jumping around a little bit with an average of .5 volts.
aure you running really rich or burning excessive oil? Sounds like carbon buildup.
The only accurate way to test a o2 is with a scanner. You should have crosscounts from about 200mv to 800mv, with the center around 450mv (stoich).
Once the o2 is reached 600deg, you can get an accurate voltage with a DMM, but it's not going to have a fast enough refresh rate to give the crosscounts.
YOu can get the "battery" effect going on the old one by sticking it in a vice and heating it with a torch to 600 deg, but I don't think that will give the x-counts either, just an average voltage reading.
