why is my car so crackely?!?!
Old Jun 1, 2004 | 10:33 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
i just put a 3 inch exhaust with a flowmaster muffler on my 85 t/a. it sounds really nice and all at idle alll the way up to about 3000 rpm then it gets really crackely. it doesnt make any difference if i am reving it or just nailing the pedal off of the line it gets all crackely after about 3000 rpm what could cause this. my air pump is not running and i have no catylatic convertor
Old Jun 2, 2004 | 09:01 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's a combination of no cat and the Flowmaster. Which one did you use? I've got the 80-series cross-flow.
It's the famous "Blowmaster" sound, as some call it. You either love it or hate it. I wasn't particularly fond of it at first, but it's kind of grown on me (I do have a cat as you can see). I honestly don't know if the sound has changed or if I've just gotten used to it.
If you want to mellow it out a little, put a Dynomax Bullet muffler where the cat is supposed to be.
Old Jun 2, 2004 | 10:56 AM
Akshay's Avatar
Probably should go w/ smaller exhaust pipes, 2.5" to 2.75"
Old Jun 5, 2004 | 08:42 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
I would put the cat back on. It will help tune the sound and get rid of the crackling sound. Don't worry about power loss, there won't be any that you'll notice.
I have a Catco 3" cat on mine and it does help tune the sound. I had tried it without it and it was very much like yours.
-Ozzy
Old Jun 6, 2004 | 05:58 PM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
Psst....umm, thats going bigger. You mean 2.25?
Old Jun 6, 2004 | 07:22 PM
Akshay's Avatar
On RED92BIRD305's sig. it mentions 3" back from y-pipe.
Old Jun 6, 2004 | 08:46 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I think he meant to try a pipe with a size between 2.5" and 2.75"... However, I think you'd be happier with a catalytic converter on there... I like the sound of my GTA with the edelbrock catback exhaust and my dual cats (my old bird had this system on it with just a pipe in place of the cat).
Old Jun 6, 2004 | 11:26 PM
Engine: LO3 and LT1
i have been told that a cat will make it sound better and my 92 is also not as crackely and it has a cat. speaking of i just ordered the hooker cat back for that one how does that sound any one know??
Old Jun 8, 2004 | 02:54 AM
C20T/A's Avatar
Car: C-20
Engine: 260 boat anchor Mexican 350 (crate) TPI (MAF)
Transmission: THM-400 I turn 3500 (which is where my pos engine's power starts droping off) at 80 I need a 4L80-E
could you post a sound clip so we know what you are talking about.
I have no cats with flomasters and the sound mine makes over 3000 (closer to 4500) is closer to what you hear when a nascar is accelarating.
Old Jun 8, 2004 | 08:28 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
side note, if you hear a crackely pop, esp on decel, then its most likely from a exhaust leak.
Old Jun 10, 2004 | 11:03 AM
Engine: LO3 and LT1
u dont know how to post a sound clip
Engine: LO3 and LT1
i* dont know how to post a sound clip
Old Jun 11, 2004 | 12:38 PM
Engine: LO3 and LT1
what do in need to post a sound clip and how do i do it
Old Jun 12, 2004 | 10:58 AM
Ozzy88GTA's Avatar
Engine: 5.0 TPI
Post it the same way you'd post a link to an image that's located on a web server. That means if you have a .wav, .mp3, or whatever, you'll have to transfer it from your computer to a web server, usually the free server space given to you by your ISP. Then you post a link to that file. Very simple.
-Ozzy
Old Jun 16, 2004 | 10:17 AM
Engine: LO3 and LT1
what can i use to record the file
Old Jun 16, 2004 | 12:01 PM
no_car_yet's Avatar
i think i may hav the same issue. i have asmall video file here(700KB) and at around 11-13s in i rev it to about 4000...turn up your speakers to hear it better..
i have hedman headers, a 3" borla cat-back, and remeoved cat. 305 tpi.
heres the vid of my GTA... (0.7MB)
http://www.nf-fbody.com/videos/JustinSmith.wmv
Old Jun 17, 2004 | 12:15 AM
Ozzy88GTA's Avatar
Engine: 5.0 TPI
To record your sound files there are many ways but I'll give you a few examples using a PC.
You'll need a microphone, that's a given. Then you'll need sofware to capture the sound and encode it to a file format of your choosing. The most common file formats are wma and MP3. A wma file is uncompressed so it's going to be big but an MP3 is compressed so it might only be about 1/4 the size depending on the bitrate you encode.
You can download Windows Media Encoder "here" for free. WME works with video also if you have a camera. Another freeware download is MESSER , I use this one to record from my audio sources directly into MP3s at any bitrate. You'll need the .dll files "Blade Encoder" for MP3s and the "Lame Encoder" for wma files which are downloaded from separate sites.
There are many other ways but these are the ones that I use. The sure way to go would be with the Windows Media Encoder since it is from a trusted source. The other one I've been using for a while and never had trouble but the blade encoder which is downloaded separate from sources in Europe, and you'll need to be carefull where you download from. You can also check Download.com and SnapFiles for more freeware software to record sound.
Remember the WME files are going to be a bit bigger but most sound clip of exhaust are not that long anyways.
Good luck,
-Ozzy
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
kyleb24
Aug 15, 2015 08:24 AM
Poncho92
Aug 7, 2015 08:15 PM
