V8 y pipe problem after motor swap
Old Jun 3, 2004 | 10:37 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
I swapped in a v8 in place of my v6. Now no matter how tight i tighten the pass side exhuast manifold bolts (i dont have headders yet) though the y pipe i still have a small gap left which makes a major exhuast leak! The drivers side exhaust manifold is kinda angled to seal with the y pipe. The pass side is flat and smooth..
Does it need a donut?
Help please! Im done with the swap and this is my last problem.
Old Jun 3, 2004 | 10:47 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
how big of a gap is it, like an inch or 2? if so you need to get the heat riser thats suposed to be there and then bolt everything tight.
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: V8 y pipe problem after motor swap
Yup there should be a donut IIRC. It has been awhile since I put my headers on but I am sure I had a donut on at least one side.
Old Jun 3, 2004 | 10:52 PM
br()bert's Avatar
Car: 85 firebird
Its not that big of a gap, like 1/2 an inch between the y pipe and the exhaust manifold. I dont know what you mean by the heat riser .Everything is on there that came on it besides the air tubing that i removed and plugged.
Thanks Shifty, ill go get one tomorrow and throw it in.
87350IROC's Avatar
Car: 87' IROC
There is a approx 1" metal spacer that needs to go inbetween the manifold and y-pipe. You could prolly find one at a junkyard or from someone getting headers.
JP
Old Jun 3, 2004 | 10:55 PM
br()bert's Avatar
Car: 85 firebird
I hope a parts store near me has one because i need to get this fixed by this sat.
Old Jun 3, 2004 | 10:58 PM
87350IROC's Avatar
Car: 87' IROC
I kinda doubt a parts store will have the spacer. What engine did you put in and what is the y-pipe out of?
Old Jun 3, 2004 | 11:01 PM
br()bert's Avatar
Car: 85 firebird
the engine is a 90 350, it was a tpi motor, now its carbed. The y pipe is from autozone brand new . There computer had the same part number for a 85 v8(my car year) and a 90 v8 (motor year)
Its really not too big of a gap. Just big enough to make a huge exhaust leak.
Old Jun 3, 2004 | 11:03 PM
87350IROC's Avatar
Car: 87' IROC
If the y-pipe is meant for a 350 car then you def need the 1" spacer. It doesn't do anything like a heat riser would, it just fills the space. I had the same thing on mine. No gasket needed.
Old Jun 4, 2004 | 09:58 PM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Yup. Call it a donut or a spacer, but the passenger side gets one, driver's side doesn't. It's probably about 1 1/2", but you've got your Y-pipe tighten way up on that side now without that donut in there. If you had the donut, it would've stopped tightening way before it is where it is now.
One side of the donut is flat to match up to the flat bottom of the passenger side manifold, and the other side of the donut is "balled" like the bottom of the driver side manifold to fit into the Y-pipe.
If you could wait long enough to get one shipped to you, Tom at www.houseofcamaro.com has them. But like 87350IROC said, you oughta be able to find one pretty easily at a junkyard.
Old Jun 5, 2004 | 09:13 AM
br()bert's Avatar
Car: 85 firebird
Thanks guys, ill probably order one because i dont think a y pipe is gonne be too easy to remove in a yard.
Old Jun 5, 2004 | 09:45 AM
ljnowell's Avatar
maybe you can score one cheap, like that carb.
Old Jun 6, 2004 | 03:05 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
LMAO.....
Old Jun 6, 2004 | 03:26 PM
br()bert's Avatar
Car: 85 firebird
Hmm, thats funny. It says that someone replied to this thread but when i come back to check i only see my last reply. Must have been some childish loser i have on ignore.
Anyway, A guy i know has one but its all rotted and rusted REAL bad. Guess ill just order one.
Old Jun 6, 2004 | 03:39 PM
ljnowell's Avatar
yeah, maybe you'll get a good deal on it.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Mar 5, 2017 06:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
