Finally passed emissions, pic
Old Jun 23, 2004 | 01:41 PM
Mike89GTA's Avatar
I didn't pass before, with the new Catco cats I passed. Why is my HC so high?
Old Jun 23, 2004 | 04:20 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Is your compression high? I remember being told that higher compression engines see high HC levels.
Old Jun 23, 2004 | 10:38 PM
MdFormula350's Avatar
congrats, feels good to pass..
i passed HC by one point
Old Jun 24, 2004 | 08:20 AM
VA1991Z28's Avatar
Car: 1991 Z28
Transmission: 5-spd
My 91 Z28 LB9's HC:
15MPH Limit 98 Actual 91
25MPH Limit 96 Actual 94
Congrats on passing! I was glad to pass also. Where are you in VA? I'm in Leesburg.
As far as why your HC's are so high, are there any other problems with the car? Stalling, idle, tuneup needed, etc..? I know I have at least one bad cat and it has developed a stalling problem when warm and coming to a stop. I need to check my IAC & TPS. Also do you have any leaking injector's? A believe a rich condition could raise the HC's. Just a thought.
Old Jun 27, 2004 | 05:20 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i worked for an emission testing place here in ohio and HC's are unburned fuel basically poor combustion. or your converter isnt burning the extra fuel off as it should. just to let you know from what i was taught
Old Jun 29, 2004 | 02:21 PM
wesilva's Avatar
Transmission: 200R4
87CIZ is correct. Asked some emissions experts and unburned fuel is the problem. Crevice areas or areas in the combustion chamber where the flame can't travel is one mayjor area of concern. The ring grooves, the space between the head and the deck surface of the block, even the arrow cast into the top of a pistons are "crevice areas"...interesting.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
aaron7
Aug 17, 2016 06:02 PM
InfinityShade
Feb 21, 2016 01:29 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
jimmy harris
Aug 31, 2015 03:09 PM
