SLP y-pipe
Old Jul 12, 2004 | 10:42 PM
87350IROC's Avatar
Car: 87' IROC
SLP y-pipe
I recently installed the SLP 1 3/4" headers and i have an exhaust leak on the passenger side collector. It is like the y-pipe is not bent to the correct angle to meet with the header straight. Has anyone else had this problem? How did you fix it? SLP insists they just need to be 'adjusted', BS there is no way to adjust the passenger side of the y-pipe without moving the cat too. I've done headers before, i know how it is done, SLP just won't own up to it.
thanks
John
Old Jul 12, 2004 | 10:43 PM
87350IROC's Avatar
Car: 87' IROC
Old Jul 12, 2004 | 10:45 PM
87350IROC's Avatar
Car: 87' IROC
3, its cool how the collectors turn neat colors, the driver side is a nice purple
Old Jul 12, 2004 | 11:05 PM
laiky's Avatar
if you can get the bolts in they usually relax some after a few heat cycles. Mine didn't fit too good either at first. I highly recommend you get a walker catalog and get the solid steel donuts instead of the ****ty lead ones. The steel ones last indefinately, and aren't destroyed by small leaks. Also they retain bolt torque much better as they do not erode away
Old Jul 12, 2004 | 11:18 PM
laiky's Avatar
on the issue of quality, SLP seems to use good materials but with shotty construction. Nothing i have bought from them has fit right and there customer service is an embarrasment
87350IROC's Avatar
Car: 87' IROC
I've retighened them and played for a few hours trying to get them to line up with no luck.
Old Jul 12, 2004 | 11:21 PM
laiky's Avatar
those solid donuts help the pipes pull together a little better than the lead too
Old Jul 13, 2004 | 12:31 PM
87350IROC's Avatar
Car: 87' IROC
Its worth a shot. thanks
Old Jul 14, 2004 | 07:53 PM
BOTTLEDZ28's Avatar
Transmission: A4
have you addded new poly motor mounts? those rasie the engine a little and this may cause the rest of the exhaust to be off a little bit. My SLP setup fit good.....I think. I will check it this weekend. I just re installed it all for the 4th time and it seemed to go in pretty good. I used the SLP dougnuts which I really did not want to use. Anyone have the part number of hand for those walker ones.
Old Jul 14, 2004 | 09:24 PM
87350IROC's Avatar
Car: 87' IROC
No, stock mounts with 60,000 miles. I got the advanced auto ones, pn 5185157 $1.04 ea
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
