eliminating converter-by adding straigt pipe
Old Jul 13, 2004 | 01:53 AM
CRAZYCHUCK13's Avatar
Car: 91 Z28
Engine: 383-Carb
Transmission: TH400/3500 Stall
i live in indiana,the emisiion laws are supposed to change.can i replace the catalitic converter w/a straight pipe?will the ecm log codes & will there be any performance problems?
thanks
chuck
p.s.what other mos will i
or do i have to make& can i
expect hp increaces?
Old Jul 13, 2004 | 06:23 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
You sure can.
If you want to make it easy on yourself to put the cat back on, y ou can flange everything like I did. It makes putting the cat in, and easy 10 minute job.
Old Jul 13, 2004 | 10:00 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, you can, for "off-road use only".
It's a violation of Federal law to modify emissions systems with non-certified replacement parts or to make inoperative such emissions systems for vehicles operated on public streets, roads, highways and by-ways.
(Just making sure the "truth" is given, along with all the other advice you're bound to get on this thread.)
Old Jul 13, 2004 | 07:53 PM
GTA_JOE's Avatar
Car: 2 1988 GTAs
Engine: 5.0 and 5.7
Axle/Gears: 3.27 posi's in both
If any shop does it for you they are breaking the law. If you do it yourself you'll be ok until they start doing inspections again. EPA fines shops $2500 for removing a cat. I took mine off myself and ran a cutom made set up I built myself. As long as they don't do emissions testing here ever again I'll be fine.
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
Night rider327
Oct 9, 2015 09:25 AM
gord327
Oct 3, 2015 01:25 PM
