Hedman LT's and a T-5
Old Jul 14, 2004 | 05:54 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys, I have tried a search but I can't find a definate answer on the topic, I am looking to put some Hedman long tube headers on my formula, I woudl get the 68460's. Now I have a t-5 trans in the car and I need to know If the headers are going to clear the slave cylinder and what not. Thanks for any help guys..
Old Jul 14, 2004 | 11:04 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
my hooker long tubes clear the slave cylinder if that helps any.
Old Jul 14, 2004 | 11:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The Hookers are a lot lower than the Hedmans though.
Old Jul 15, 2004 | 09:46 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://www.hedman.com/pages/hedmanmain.html
Footnote #135: "Transmission size limited to 700R4 and 350 Turbo."
#109 is also interesting: "Dual exhaust only, limited ground clearance."
Old Jul 15, 2004 | 02:52 PM
biff85ta's Avatar
Car: 04 Vette
109 Is bull and I can prove it.
Old Jul 17, 2004 | 03:43 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
I had a set of the Headman longtubes on my old 86 TA with the T5. You will need to grind down the bell housing around the slave cylinder, as well as dimple the collector to get enough clearance. I regretted getting the Headman LTs after they were on.
Old Jul 17, 2004 | 07:31 PM
tommyboy's Avatar
Car: 87 Formula
Engine: 355
Transmission: TH400
Axle/Gears: 5.00
They will not fit. Do not grind down the bell housing near the slave cylinder. You need to notch and weld the header for it to fit. I did the same thing last year. If you are looking for a set already done, I have a set.
Old Jul 19, 2004 | 02:22 AM
IROCFAST's Avatar
I didn't have to notch or grind anything...worked out well for me.
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
Zell1luk
Sep 29, 2015 10:36 AM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
