Hooker 2055 questions
Old Jul 14, 2004 | 11:03 PM
BWright
Guest
Posts: n/a
I just received my Hooker 2055 headers coated from ACS for 91' RS 305 w/ TBI. I noticed the O2 bung is welded on the back(firewall) side of the collector on the driver's side. Stock manifold has the sensor pointing forward. Will this be a problem during install? Looks like there's enough clearance to the rear for the sensor, but I dont think the wire will be long enough to reach around to the rear. I was wondering if the bung is welded on the back for some engines, and should be welded to the front for mine.
I got the headers with the EGR tubes since I plan to keep all emissions equipment. Are there any fit up issues hooking all the EGR equipment to the new headers? Passenger side header install looks like it will be a real adventure!!
Old Jul 14, 2004 | 11:50 PM
25THRSS's Avatar
First off those tubes are not for the egr, they are for the AIR system. With that aside, the o2 bung is welded to the rear because it would contact the k member if it was in the front. just stretch your o2 wire some or you could buy an o2 extension.
Old Jul 14, 2004 | 11:53 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You will have enough slack in the stock harnes to connect your 02. Virtually all shorty kits tailored to 3rd gens are this way for the clearance reasons 25TH mentioned.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
billybob6110
Sep 24, 2016 09:50 AM
formula_novice
Sep 5, 2015 03:58 AM
tricky1
Aug 23, 2015 01:17 PM
redmaroz
Aug 16, 2015 11:40 PM
