fabricate air injection on lontubes?
Car: 88' formula
Engine: TPI 305
If I buy the Hooker Super comps. for my car, could I weld on a piece to make air injection for emissions purposes?
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
I dont see why you couldnt, drill some holes, and use some big brake line or fuel line, I dont know if those two lines hold up to the heat but im sure some tubing will.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yea, that would work fine. As long as they are steel tubes, they will work. Shouldn't be hard to make either, as almost any parts store will rent you a tubing bender that can handle that size of tube.
In addition: If you are trying to make LTs emissions compliant, you will need to keep the 02. And with the collectors being so far from the engine, you will need a heated 02. Remember, you also need to keep a y-pipe and the catalytic converter(s) in the stock location.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
