?'s about header/exhaust install
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
i'm in the process of removing my stock exhaust right now and haven't even decided what i'm going to do with the rest of my "project" yet. i have a '91 Z28 5.7 TPI with dual cats and have SLP 1.75's SS headers and flowmaster american thunder catback standing by. also, the car has AIR and A/C. i've been reading up on the other posts about recommendations, etc., but some of the ?'s i have are:
1) what is the real benefit of coating the headers and the cost?
2) i need to replace both cats, so a recommendation?
3) what other pipes will i need to complete the install?
i'm new but not blind to doing the exhaust, but with the set-up i have standing by, i think i need the y-pipe from the cats to the outlet cuz i think the collector pipes came with the headers... (i say i think cuz i bought them years ago, believe it or not). also, i recall an "installation kit" for the SLP's, so maybe that should be it, other than the obvious gaskets and bolts?
i just got the stock cat-back cut off my car and haven't removed anything else yet, because this all started as a trouble-shooting effort from suspecting a clogged cat, which proved to be true.
as for the rest of the "project" i mentioned, i have a rear main oil leak and valve seals leaking, too, BUT - other than that, car is running great. so... my thoughts were to pulling the engine and fixing it all out of the car and doing some under-carriage clean-up, too. not looking for any big performance changes, other than to do some gasket-match porting and maybe bump up the cam a little. tranny is still good to go, rebuilt about 30k ago.
thanks for looking, would like to hear your recommendations. i have til the end of the year to get it all done, so time is not a huge factor...
KAM
KAM
Transmission: 4L80E/4L80E
The main benefit of coating SS headers is reduced heat transfer from the exhaust gases to the engine compartment. Secondary benefit is they will look nicer longer. Cost is ~$150-$200.
The best bet is to get the installation kit and direct fit cats. That is assuming you bought headers for dual cats. Anything else will bring installation/fabrication headaches.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
not to mention the fact that they wont rust up on you badly
Car: '91 Z28
Axle/Gears: 323's
KAM
gixxer92
Sep 1, 2015 04:32 PM
