optimum header length v rpm
Is there somewhere online, some type of chart that
displays: RPM vs the optimum header (primary) tube length,
hopefully with several tube diameters?
My suspicion is that so called 'long tube headers'
are too short.
are too short.
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
http://www.headerdesign.com/index.asp
Register for the site above and put in your parameters to find the optimal header length.
Larger primary sizes shift the torque peak higher in the RPM range.
A shorter pipe for a given diameter kind of "rocks" the whole graph around the peak, lower RPM having less torque and higher RPM gaining some.
The opposite happens with a longer primary pipe for a given diameter.
EDIT: I got it backwards.
here's another link about header pipe sizes and lengths:
http://www.popularhotrodding.com/tech/0310phr_burns/
I happened across some intenet site, with a header length
calculator, I put in the numbers for 5000 RPM,
and was reported an optimum lenght of 60 inches.
Does that seem right?
I fully realize that lenght, is not what header vendors
want to sell you.
want to sell you.
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
