true dual
Old Aug 17, 2004 | 07:15 AM
psychobowtie's Avatar
Car: 1987 camaro
Engine: 2.8 it sux
Transmission: 700 r4
true dual
does any one know if its possible to run a true dual exhaust out of a third gen f body? some one at a custom exhaust said it was impossible becuase of clearance issues is he right or has it been done.
Old Aug 17, 2004 | 07:29 AM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
well you must not have seen the stick thread above yours thats been there try a or just look at the sticky thread that would answer all your questions
Old Aug 18, 2004 | 09:01 PM
RICHRAD's Avatar
Yes it's possible, but both pipes must follow original exhaust path... can't remember exactly how the mufflers position..
Old Aug 18, 2004 | 09:11 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I wouldn't quite say 'must'...
Old Aug 20, 2004 | 08:51 PM
RICHRAD's Avatar
To be more specific..."must follow original path for proper clearance unless your into *******ing the thirdgen"
Old Aug 20, 2004 | 09:54 PM
deadbird's Avatar
Engine: TPI 305/ v6
I'm not positive on your purpose of your lowbrow retort but, you're still wrong.
*edit.. psychobowtie.. there is a sticky at the top of this forum that covers all bases of dual setups on these cars.
Old Aug 20, 2004 | 10:26 PM
RICHRAD's Avatar
Old Aug 20, 2004 | 10:57 PM
mgray10's Avatar
Car: z28
Ironically enough, better clearance is to be had using methods other than the stock routing. It is simply a matter of perspectives with regard to what is considered "********ing the thirdgen". So if you are so bold as to think your perspective is the only perspective of logic, well then you are not very logical.
Back at the ranch. . .
:lala: :lala: :lala:
Old Aug 20, 2004 | 11:02 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Duals are possible but they have many downfalls. 99% of dual exhaust systems installed on these cars DO NOT use the stock routing. Pipe size and collector location sorta prohibit that. Therefore, ground clearance is seriously compromised along with a clear route to the rear of the car. Read the sticky at the top of the page. It covers pics and plenty of "how to's". ALso, try a search or two. This question comes up every day.
mattcanty
Oct 12, 2015 11:08 AM
paul_huryk
Oct 1, 2015 04:27 PM
