SLP tri-y's on ebay, just a heads up if anybody was interested
Old Sep 2, 2004 | 02:12 AM
JPrevost's Avatar
Car: 91 Red Sled
http://cgi.ebay.com/ebaymotors/ws/eB...category=33631
Stainless steel, plenty of room to work around, unique, wow factor. Tri-y's aren't the best but they're pretty darn good. They were designed for the first Firehawks of 91 and 92, then there were extra for sale, my car just happened to come with them.
Sold for like $1200 back in the day , definatly not worth that much but again, they're a rare find on todays thirdgens.
Old Sep 2, 2004 | 06:03 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Thanks for the heads up
Old Sep 2, 2004 | 09:02 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
A pipe/cut-out has been welded in place of the cat, with an A.I.R. tube where the cat A.I.R. tube would have been.
Looks like some sort of damage (hole?) just before the final Y joint - I couldn't get good enough resolution to tell for sure what it might be.
The tri-Y concept is an intriging one. Not sure there's much advantage over simple shorties, though.
Old Sep 2, 2004 | 09:05 PM
MdFormula350's Avatar
alittle beat up looking, but nice find indeed.
also i am pretty sure they only had 1 5/8 "Tri-Y" 409 Stainless Steel Tubular Headers
Old Sep 2, 2004 | 09:16 PM
65panhed's Avatar
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
these headers were only made in 15/8" according to SLP.I spent 580.00 for mine unused ebay and 150.00 for coating inside and out. Though I have nothing to compare them to, mine run great with the other mods.easy to install and I cut the air tubes off at 3/4" and capped the tubes with hex pipe caps, it cleaned them up very well.........and yeah that looks like a hole........also the 4 bolt flange gaskets are available from SLP 20.00 per pair
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Mickeyruder
Sep 2, 2015 02:45 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
89mulletbird
Aug 12, 2015 07:08 PM
