Cut-out in place of cat?
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
My 2055's should be here in a few weeks and I was going to put a high-flow cat on, then hook that up to my 3" Edelbrock cat-back. I was wondering if there's an electric, or the cable-style, cutout that is a direct replacement for a standard cat? I'd like to be able to open and close the cutout from inside the car. Is there any cutout that will get close to fitting or will I have to get one and take it to a muffler shop and have them weld it on?
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
if you want to open and close the cutout from inside, the electric one is the only way. More than likely you'll have to weld it into the piping...and if you want to wake up the the dead, put it in before the cat (between the y-pipe and the cat), thats pretty much open headers when you you flip it!!
Car: Kitt
Engine: Classified
Well I want a cutout in place of a cat. When it goes headers, y-pipe, cutout, then cat-back. Are there any electic cutouts that are direct replacements for cats?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The route I took, which does cost more money that most would spend, was to buy a mac offroad pipe, which is a direct swap with the slip fit 3 inch cat, and weld a cutout into that. It's a really sweet setup and almost looks factory.
Car: 1990 Trans Am GTA
Transmission: 5-Speed
www.quicktimeperformance.com
This is wat your looking for if it's an electric cut-out that you want.
Car: Kitt
Engine: Classified
Thanks, I guess I'll just have to go to an exhaust shop and have them fab up a pipe to connect my y-pipe to the cutout to the cat-back...
[Sold] Flowmaster exhaust system
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
