Hooker 2210 clearance with straight angled heads?
Old Oct 3, 2004 | 02:45 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Anyone have 2210 and straight angled heads? how about the clearance for the plugs?
/N.
Old Oct 3, 2004 | 09:16 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I have straight plug heads and yes I had serious clearance problems. The #7 tube is the worst I had a friend cut the tube and replace it with another that bends out further from the head. I ended up not using the headers at all even after all that because they also hit the crossmember and brakelines very badly. I bought a set of hedman long tubes and they fit very well with great sparkplug clearance, I can change all the pluges in about 15-20min with a short 5/8 wrech. I know most people have not had as much clearance problems with the Hooker LT's as I did, thats just my personal experience. I want to eventually use the Hooker LT's because of the larger 1 3/4 tubes but I'm going to wait until I get a tubular crossmember so I can avoid most of the clearance problems.
Old Oct 3, 2004 | 10:05 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yeah i got the 2210's with straight plugs and i modifid a spark plug and i have no clearence problems at all. heres a pic of how much clearence i have with my modifid plug and i didnt have to dent any tubes or anything.
Attached Thumbnails Hooker 2210 clearance with straight angled heads?-clay8.jpg
Old Oct 3, 2004 | 11:22 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
What part.nbr for the headmans?
/N:
Old Oct 4, 2004 | 06:27 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
How did you modify the spark plug if you don't mind me asking . I've got some Vortec heads ready to go on my new motor & really wanna use the 2210s. If it's too much hassle to make that modification to the spark plug then I might just go with Hedman.
Old Oct 4, 2004 | 11:08 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
i took the plug, marked how much i needed to take off and then took it to my bench grinder and grinded off the ceramic part and then after that was off and the electrod was exposed i cut off the rest i didnt need after findin how much i would need to screw on the top piece for the plug wire. after that i used a Die and made the threads and then wala its done. takes awhile on the grinder but works great so far after a 1 1/2 yr. and then for the spark plug boot , i just trimmed it to fit.
Old Oct 4, 2004 | 05:16 PM
Car: 89 RS
Did you happen to take any pictures while doing the mod to the spark plug? I like visuals lol
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
87iroctheo
Dec 4, 2016 11:47 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
tricky1
Aug 23, 2015 01:17 PM
