Breslin vs. Stage 8 Header Bolts
Old Dec 6, 2004 | 12:46 AM
chomp's Avatar
Car: 1992 Camaro RS
Engine: 305 V8
I'm going to be installing some Hooker 2055's on my car probably within the next week and I need to get some locking header bolts.
Should I go with Breslin: http://www.go-breslin.com/text.html
or
The Stage 8's: http://www.thunderracing.com/catalog...&vid=6&pcid=54
Old Dec 6, 2004 | 09:06 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
That's a tough decision. It depends on what you want to spend. Price wise it looks like the Stage8 are the better deal. Now that's not to say that they are better. Another thing to consider is the allen bolt in the Breslin. In a discussion a while back it was brought up, what would happen if the allen bolt seized up in the bolt? I'm not exactly sure if they have a problem with that but it might be a good question to ask Breslin about. As for stage8, I know that I had very few problems getting mine to work with my headers but once they were on, they work.
Opinion wise, I would probably go with Stage8 again if I had too. That's only cause I don't have the 411 on the breslin since they are still kinda new on the market compaired other locking bolts.
Old Dec 6, 2004 | 06:56 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I like the design of the Breslins much better. I was only able to use a few of the locking tabs on the bolts because of the location of the primary tubes to the bolt holes. Every header will be different but be it as it may I still had to back some of the bolts off to get the tabs to lock-up. I also, wasn't about to take a grinder to the $40 tabs that wouldn't fit. It is a good idea but it is to universal to be effective on all set-ups. The breslins will be.
Old Dec 10, 2004 | 02:00 AM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
I've used a grinder on all the sets of Stage 8s I've ever used. It's easy, they'll stay on, and it won't hurt them.
Old Dec 14, 2004 | 07:55 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Antiseize is always a good idea on any header bolt, it's saved me several times.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
toronto formula
Nov 10, 2015 06:17 AM
hayesaw0210
Aug 23, 2015 11:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
