Air Tube Delete Plugs
Old Dec 16, 2004 | 07:08 AM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Ok just a quick question. If it's a dumb one don't laugh
When deleting the air tubes off the stock manifolds, it's recommended to use brass plugs. What is the reason for that? Is it just in case you might want to take them out in the future?
Would steel plugs be ok if I'm not planning on taking them out later? Any info on this would be great. Thanks!
Anthony
Old Dec 16, 2004 | 11:33 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I'm not sure what the stock tubes are made out of but I just cut the tubes off the flare fittings and welded the ends closed to use the stock fittings. Works fine.
Old Dec 16, 2004 | 12:10 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
steel will work fine.
it would just be a major pain to remove them later on....
Old Dec 16, 2004 | 02:28 PM
Car: 89 RS
That's what I thought. Just had to make sure. Thanks
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
drathaar907
Aug 6, 2015 04:20 PM
