exhaust gas coming through vents
Car: 1991 camaro rs
Engine: 383 stroker
Transmission: th350
i just got my car back to day with the 3" y-pipe installed...haven't gotten the rest of it done yet, don't know what type of muffler to go with. anyway, while driving with the heater on i can smell it coming through the vents and when i get out i reek of exhaudt fumes...is this just because i only have the y-pipe on or could it be something else?
Car: 1991 camaro rs
Engine: 383 stroker
Transmission: th350
well i think i got it...4 header bolts, all at the back of the engine were loose. 2 of them i could spin w/my finger, after i tightened them all down car is actually running better and the AC and heater don't blow in exhaust gas.
Transmission: 4L80E/4L80E
You might want to check your cowl-to-hood seal while you're at it. You smelled it because it was unusually strong, but you're probably still getting unhealthy fumes from the engine compartment into the passenger compartment.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I know on my beater (the 91' rs), if the windows are up... not a trace of smell (or my eyes burning as they are pretty sensitive to exhaust)... windows cracked or down... ripe smells of oil and unburned gas. With the window craked, it can be bad enough to have to roll it all the way down just to defume the cabin.
Rather annoying as it burns the hell out of my eyes as well.
I've never had this problem with any other car I've had. Even my old '84 sc w/no seal didn't do this.
1992 Trans Am
May 10, 2023 07:19 PM
