Header fitment question
Car: 1984 T/A
Engine: L69
I'm in the market for a set of headers and I kinda wanted to find a sent that included a matching Y pipe or one avalible that fit the headers. I dont want to run a cat (no emmision laws here) and I want do just be able to replace the cat with a pipe to the Y pipe and the existing exhaust. I seen a few headers that I like but some of them only fit 86-92 F-bodies while some of them say they fit 82-92. What is the differance? Can anyone suggest a set of headers that come with a Y pipe that will alow a slip fit to a replacement tube for a cat?
Transmission: 4L80E/4L80E
The difference is whether or not they will bolt into the stock exhaust. If they say '82-'92, they will not.
Any header for 3rd gen SBC will fit your engine and chassis. Any headers that are emissions legal for '86-'90 TPI single cat application will have a y-pipe that has a slip fit to the cat. Hooker 2055's always come to mind because they have a very nice y-pipe included, arguably the best available. Others will do the same, but typically don't have a full 3" after the two down-pipes join before heading for the cat.
Car: 1984 T/A
Engine: L69
Not sure exactly what you meant by slip the exhaust right to it, because the exhaust won't reach. But, you can slip any 3" ID pipe onto the y-pipe end.
Car: 1984 T/A
Engine: L69
Most pipe is sized for OD. Cats are sized for ID. Therefore, a slip-fit inlet cat will slip onto the 2055 (and others) y-pipe outlet. However, a 3" piece of pipe will not. You'd have to get the pipe expanded to 3" ID for a couple of inches. Or butt weld it.
hectre13
Sep 8, 2015 03:38 PM
kah992
Aug 19, 2015 02:55 PM
