Dipstick tube after header install
Old Jan 8, 2005 | 07:10 PM
bxrman's Avatar
Car: 1988 IROC-Z Convertible
Engine: 305 TPI, LB9
I just installed a set of Hooker 2055 headers with AIR, and was wondering what you guys have done with the oil dipstick tube to secure it? It is originally secured to the manifold, but after you remove that and install the headers there is really nothing handy to bolt it to........I currently have it strapped to one of the AIR tubes on the headers, but would prefer to have a better solution.
Old Jan 8, 2005 | 09:22 PM
dual_88s's Avatar
From: In my own little world - but they know me well in here
Car: 88 Sport convertible
Engine: 305TBI
Transmission: AUTO
Axle/Gears: 3.42 rear end
did the same thing you did....wired it to the AIR tube....
Old Jan 9, 2005 | 07:11 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
mine is kind of a press fit type and i just gently tapped it in the block and it doesnt need to be fastened anywhere. you might look into that if you dont want to have to secure it.
Old Jan 10, 2005 | 02:30 PM
bxrman's Avatar
Mine is also the press-in fit (original) style, but it has a mounting tab welded onto the tube that used to be fastened to the manifold bolt. If you don't tie it to something, it can move around a bit...probably not a big deal, but I feel better with it secured.
1992 Trans Am
May 10, 2023 07:19 PM
toronto formula
Nov 10, 2015 06:17 AM
mizz0313
Aug 12, 2015 06:45 AM
drathaar907
Aug 6, 2015 04:20 PM
Leggman1
Aug 6, 2015 04:15 AM
