T.p.i Header's On T.b.
Old Jan 12, 2005 | 04:50 PM
DA 89 CAMARO's Avatar
Car: 89 RS,97 Z28
Engine: 305 T.B.I,350 LT1
Transmission: T5,T56
I read a couple of tread's but I'm still not sure.I have T.B Injected engine right now but soon I plan to put a tpi system pretty soon.so I was wondering can u put tpi header's on a T.B. engine
Old Jan 12, 2005 | 05:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, you can. Highly recommended even if you stay with the TBI set-up.
Old Jan 12, 2005 | 07:02 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
do you have to modify anything to make the tpi headers work on a tbi?
Kyle
Old Jan 12, 2005 | 07:07 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Kyle
Nope. Everything is in the exact same location. All Gen I and Gen II motors share that in commong . Doesn't matter what motor it is.
Old Jan 12, 2005 | 11:18 PM
RebelRacer's Avatar
Car: Bitchin' 92 RS
sorry for the domb questions, but what about the y pipe?
thanks
Kyle
Old Jan 13, 2005 | 12:07 AM
five7kid's Avatar
Get headers with a y-pipe. Otherwise, there will have to be modifications made - no headers bolt to the factory y-pipe.
The cat inlet is bigger for TPI than TBI. The hot setup is to replace the entire TBI exhaust system with headers, cat, and catback for the TPI application.
Old Jan 13, 2005 | 10:03 AM
dual_88s's Avatar
From: In my own little world - but they know me well in here
Car: 88 Sport convertible
Engine: 305TBI
Transmission: AUTO
Axle/Gears: 3.42 rear end
IF (while still a TBI) you want to hook up your Thermac, Hooker makes a part/adapter to do so. 10930HKR check it out on the Holley website.
Clamps on to your new header and provides the thermal feedback to the air cleaner assembly....
Look at it close and hard enough and you MIGHT be able to make your own. Then when you switch to TPI, just remove the clamp and assembly.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
