any tricks???
Old Jan 15, 2005 | 02:01 PM
emtcee's Avatar
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
any tricks???
i think i have a header leak somewhere.either at the header flange or the collector.are there any tricks to see where its coming from?kinda like using propane to find a vacum leak.its hard to put my hand near it cause its rea hot.anyone have any ideas?
thanks,mike
Old Jan 15, 2005 | 04:21 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Re: any tricks???
thanks,mike
You'd spend less time replacing both gaskets than you would trying to find the leak.
Old Jan 17, 2005 | 12:13 AM
sickstrings84's Avatar
Car: 2003 Chevy Cavalier LS
Engine: 2.2 I4 ECOTEC, crane cam, FAST piggyback ECU
Transmission: 5 spd
I must agree man, throw on some gaskets and you'll save a couple hours trying to find the leak.
Tim:rockon:
Old Jan 17, 2005 | 01:46 AM
Night rider327's Avatar
Car: 1988 Camaro
There's 2 ways of checking.
1) look to see if you see any black soot anywhere close to the flanges, like the tops of the gaskets, bottom rail of valve covers, etc
2) get a lenght of 3/8"-1/2" rubber hose. Put one end to your ear, and move the other end over the tops, bottoms, sides of flanges. The hose will block out alot of the sound and make where every you put the other end alot louder. So if you place it near an exhaust leak you'll know it fast. It will be loud!!
Make sure all your bolts are tight.
If you need new gaskets, I recommend copper collector gaskets. Summit has there brand for $10 for both collector gaskets, new stainless bolts, lock washers and taps.
For the flange gaskets, I recommend stock foil faced manifold gasket set, if you have square tube flanges. You know the stock type 3 gaskets per side type. They work alot better than the cheap paper 1 pc. header gaskets, and not near as high as copper flange gaskets ($30-50)
But you have to match the header flange tubes to the gaskets. If you have round ones, then you cant use the manifold gaskets and will need round hole header gaskets
timonator
Sep 30, 2015 12:52 PM
RS Reaper
Sep 27, 2015 07:04 PM
Justins86bird
Sep 27, 2015 09:43 AM
92projectcamaro
Sep 24, 2015 08:09 AM
project89
Sep 22, 2015 09:35 PM
