catalytic problems
Old Feb 16, 2005 | 12:30 PM
killthefetus17's Avatar
Car: 1989 firebird
Engine: 2.8L V6
Transmission: auto
catalytic problems
my cars stalls when i put it into reverse or drive when the rpm is under 1000, i was told my converter is clogged, i drilled holes in my converter, and it helped out alittle bit but still stalls sometimes, should i just get a new converter, or is it a bigger problem
Old Feb 16, 2005 | 01:36 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Take the converter off and see if it runs properly. If it does then that's the solution and you should get a new converter.
Old Feb 16, 2005 | 01:42 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I read a lot of articles saying if your converter goes bad, there is most likely another problem (like running extremely rich). Supposedly, converters should never go bad on a good running/tuned motor.
Old Feb 16, 2005 | 02:10 PM
Car: 1989 firebird
Engine: 2.8L V6
Transmission: auto
theres also alot of white smoke comming from the exhaust, i figured its just a seal, but could it also be because of the converter, i bought my bird for $250 off a friend, he said he had no problems with it until the converter went, the engine runs nice and after i drilled the holes, i noticed an increase in power
Old Feb 16, 2005 | 02:53 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Drilling the cat most likely broke apart the material inside the cat. Your better off buying a new cat before a big chunk of it breaks off and goes in your muffler.
Old Feb 16, 2005 | 03:56 PM
Car: 1989 firebird
Engine: 2.8L V6
Transmission: auto
would it be better to run a straight pipe, rather than have my junk converter, just until i get the money for a new converter?
Old Feb 16, 2005 | 05:07 PM
CraZ-28's Avatar
Car: 1991 Z-28
Straight pipe would be a start. From there you can check the car out and see if it has any other problems.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
