Hooker 2210's and Lowered
Old Feb 20, 2005 | 04:21 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
This spring I will be putting in eibach's pro kit. I will also be doing an engine swap and would rather use a 1.75 longtube header. Will the 2210's scrape on everything or have some of you guys had luck with the 2 together? Other setup I was planning on was 2460's with the new y pipe hooker came out with. TIA
Old Feb 21, 2005 | 08:36 AM
esc's Avatar
esc
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
I have the Hooker Super comp long tubes. Those are the 2210 right?
My car was lowered, but I had to prop it back up to almost a stock ride hight to keep from banging the collectors on EVERYTHING. The Y pipe I made sits higher than the header collectors. I used oval tubing with the Y behind the transmission.
I think that the collectors sit 2"s below everything else.
Old Feb 21, 2005 | 02:02 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
That is not encouraging. I talked to hooker about the HP difference between 2460's and 2210's and they guess I would leave 20hp on the table by using a shortie. But if it makes life alot easier I may just use the shorties.
RaverRacerX
Mar 17, 2026 01:49 AM
jbates346
Oct 21, 2015 01:50 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
Tylermcclinton
Sep 17, 2015 07:50 PM
