Hooker LT Question...
Old Feb 28, 2005 | 04:52 PM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
I need some help here. I have allready read the post about installing these over and over again... I just installed the Hooker 2210's on my 91 Camaro. The passenger side went on fine from underneath, but the driver side was a different story. I could not slide it from underneath, so I unbolted the motor mount and jacked up the engine which was still a real PITA, anyways once its in and bolted up the number one tube is making some contact with the top of the K member. Any body ever have this problem or heard of anyone with it.
Now I also just put in a T56 with a SPOHN crossmember and torque arm but I dont think that would have put a different angle on the motor. Any Help....Thanks Eric
Old Feb 28, 2005 | 06:15 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
You need to read the sticky's above.
Old Feb 28, 2005 | 08:14 PM
redimpss5's Avatar
Car: 85 z28
Engine: 94 lt1
I went thru the stickies and cant seem to find if the hooker 2210 for the 3rd gen will fit onto my 95 lt-1 conversion?
Old Mar 1, 2005 | 04:00 PM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
I did go through the sticky above and could not find any body who had the same problem. I saw where Traxion and others had to grind the A Arm mount and move brake lines but no one who had a tube rubbing the top of a k member. Thanks though, Eric
Old Mar 2, 2005 | 05:12 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
You have weak motor mounts. The poly mounts will raise the engine up about 1/2 to 3/4 of an inch.
Old Mar 2, 2005 | 06:18 PM
rocc4u's Avatar
Car: 1992 Z28
Engine: 383 Miniram
Brand new Poly mounts...
I think that Spohn tranny mount has a little adjustments that I can make so I will check that out this weekend, Thanks for the suggestions though. Eric
Attached Thumbnails Hooker LT Question...-c-documents-settings-eric
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
ssgt usaf
Sep 21, 2015 12:45 PM
