spark plug wires for header's
Car: 89 RS,97 Z28
Engine: 305 T.B.I,350 LT1
Transmission: T5,T56
i recently installed the edelbrock TES header's and they're burning my wire's can somebody guide me in the right direction.so that i only have to buy these once.thank's
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Shorter plugs helped me - NGK, or even shorter are the Accel shorty header plugs if they've got the size you need. I've had good luck with both, just need to tighten down the screw off tips on the Accel's with pliers before installing them....
Car: 84 Z28
Engine: 383
Axle/Gears: 342 Posi
Irecently bought some plug wires from advance for a 70's model camaro and all of them were 90's. Ask for 70's wires for a camaro until they bring the ones with all 90's. After that I would get a set of wire looms. They dont have to be real expensive. Mine cost about $15.
Car: 89 RS,97 Z28
I'm going to try the accel shorty plugs' and some loom's.can somebody tell me what the tread size is on the spark plug(and reach?).i have a stock engine.thank's again
Car: 84 Z28
Engine: 383
Originally posted by 83 Crossfire TA
Any generic HEI wires will have all 90* boots
Well I hope u think $45 is cheap enough for generic wires. the wires were Accel.
You should be able to get the 8mm MSD's for close to that price...
Really, for the most part, wires are wires. My old race car used to run an odd combination of factory GM and an assortment of trash auto replacement wires for it + a few out of a couple of sets of replacement Taurus wires. Some were grey, some were black, but they ended up the perfect length to clear the headers…
it ran well that way.
Started with some Jacobs wires, then went to MSD and then finally some autozone replacements (cheap and the boots don’t melt), and we couldn’t document any performance loss from supposedly stepping down in wire quality.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
