What are my 3" y-pipe options???
Old Mar 3, 2005 | 12:34 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I bought a set of hedmans for a dual cat car, but my car is only equiped with a single catalyst. SO I want to know what I can do to get a 3" y-pipe for a single cat car. Who makes one that will work with the hedman headers, they are the shorties, smog legal. 1 5/8ths with 3" collectors. Does hedman make a 3" y-pipe????? Thanks fellas, any help would be appreciated
Will
Old Mar 3, 2005 | 07:39 AM
Chrome's Avatar
Car: 92' RS Camaro
Hedman makes a single 2 1/4" from collector into a 2.5" pipe. This is all that is available. Although, I believe Anthesis said that you can cut the pipe at the Y (It gets to like 3.5 or something where they run together before reducing to 2.5). Cut it and weld on a section of 3" pipe from there. Probably be a $10-$20 buck job from your local exhaust shop.
Old Mar 3, 2005 | 11:47 AM
norcalz28's Avatar
Then I might as well just modify the existing pipes for the dual setup and have them merge into a single 3" piece or something. Thanks.
Will
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
