Anyone here using Hooker p/n 2138?
Old Mar 7, 2005 | 08:37 AM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
These are full length/long tube headers design for 3rd gen F bodies. They have 1.5" primaries and 2.5" collectors but the best thing is that they follow the factory routing path! All you'd need to do is have a Y pipe fabbed up and you can have longtubes and stay legal with the cat/s in their stock location. These would be great for 305 and some 350 engines depending on how high hp they are.
Old Mar 7, 2005 | 10:14 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i think those are more like mid-lengths. i wouldn't run 1.5" primaries/2.5" collector if someone paid me. the 1 5/8" is more beneficiary (sp?) to even the smallest output 305's than the 1.5's
Old Mar 7, 2005 | 03:06 PM
Mongoose's Avatar
Car: 90 Formula
28" length primaries,same as the other long tubes. I was under the impression that the 1 5/8" primaries were just a tad large for a 305 but since that was the standard that's what we got. I'll be doing more research on this.
Old Mar 7, 2005 | 07:34 PM
Mongoose's Avatar
Car: 90 Formula
The stock or mildly modified 305 does not respond well to tube diameters larger than 1.5" and you'll see a definite decrease in overall power. If you have modified the car to run in the 12 second range then 1 5/8" primaries become necessary. But a larger than 1.5" primary will cause a decrease in power in a 305. A 350 can tolerate a 1.625" primary but try to avoid the temptation to go larger on a street engine. One of the few manufacturers that make an equal length street header for the 305/350 is Hooker under part number 2138. Tube diameter is 1.5" while length is 28-30" specifically for street use because the stock engine runs out of breath around 5000 rpm. The shorter tube length in designed to help the engine breath better in this range. A 12" collector extension can be used to broaden the torque curve with these headers. The Hooker unit is a traditional 4 into 1 header with the left side connecting with the right side,therefore facilitating connection with the rest of the cars exhaust system.
Quoted from "Camaro & Firebird Performance Handbook" by Peter C. Sessler and published by Motorbooks International.
Old Mar 11, 2005 | 10:44 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
I was just looking through my PAW catalog a couple of hours ago and saw those listed. I was wondering why nobody ever mentioned those on this board.... until I saw this thread.
no green
Jan 9, 2016 09:22 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
thekurlyone
Sep 30, 2015 12:54 PM
Chevykid810
Sep 28, 2015 12:57 PM
greenyone
Sep 2, 2015 03:39 PM
