Cause or Effect??
Old Mar 21, 2005 | 06:03 PM
walsy's Avatar
Cause or Effect??
(I originally posted this in V-6, but meant to post here).
Recently purchased a 1985 Camaro 2.8L TBI. Car was parked for a couple of months as it started to sputter and backfire thru TBI. Idle seems to smooth out at higher RPMs. Drove it home without too much problem. Haven't dug too deeply into the car yet, but I recently discovered that when idling for a few minutes and with the car backfiring at times thu the TBI, the cat converter was glowing red hot.
Could this be cause of backfiring (clogged cat) or effect of backfiring (too lean)
Thanks.
gene
Old Mar 21, 2005 | 07:04 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Unbolt the cat from the y-pipe and run the car. It will be a little loud but if the car runs normal than you can assume it is the cat. I would also have the timing checked. Backfiring through the TBI is an alarm for bad timing.
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
Damon
Sep 26, 2015 04:29 PM
James Sutton
Sep 23, 2015 01:56 PM
billybob6110
Sep 23, 2015 01:30 PM
ASE doc
Sep 22, 2015 03:13 PM
