Cat. Converter Question
Old Mar 28, 2005 | 12:59 AM
GravyGut's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: Auto w/ overdrive
The cat. converter is breaking up inside. When the car idles at a stop, the converter vibrates w/ an annoying pinging sound. Other than the noise its makeing, is there anything I should be concerned about? Can it cause other problems?
Old Mar 28, 2005 | 01:34 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Yes, if you are sure it is the cat, gut it or replace it.
Old Mar 28, 2005 | 12:39 PM
sellmanb's Avatar
Car: '86 Berlinetta
A clogged cat can cause many many problems, It can get so bad that your car will hardly run at all. You'll mostly notice at first that it will lose gas mileage, and decrease in performance, or that you will have a much lower max RPM.
I'd suggest replacing it with a Catco or Carsound 3" High-flow cat. It's as close to a gutted cat that you can legally get
Old Mar 30, 2005 | 12:25 PM
VA1991Z28's Avatar
Car: 1991 Z28
Transmission: 5-spd
Are you sure its the cat? Because if one of the air tubes has come free, it will bang around, depend where it has come loose. I had this happen to me, but only after my new cats were installed. I thought it was the cat going bad again, but turned out that the air tube had just broken off and was hitting the cat. Just a thought.
If its the cat going bad: loss of power, cats glowing cherry red, the rattling of the catalyst inside and drop in gas milage.
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
