Catalytic Converter question
Old Apr 10, 2005 | 07:39 AM
camaro88sc's Avatar
Car: 1988 Chevy Camaro SC
Engine: 305 TBI
hey guys, well this weekend i noticed that the welds(#1) on the heat sheild(#2) for my catalytic converter, or what im pretty sure is just a heat sheild, rusted away. so well i thought that atleast one of the welds was still there when i had looked at it. But then i had to go to the store which ment i had to go on a main road, and with about 20 cars behind me it flow off. So my question is, well first is that piece a heat shield? (I just wana double check) and is it a necessity to have that heat shield?
Old Apr 10, 2005 | 01:19 PM
sp63
Guest
Posts: n/a
if its a heat sheild id say run it, that way your car doesnt burst into flames when the cat heats up.
Old Apr 10, 2005 | 04:06 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
You really need that on there. The cat gets really HOT. I'v scene them start grass fires. Not to mention your floorboard on that side is going to get hot. If the converter is still good, you can get replacement heat shields for them.
Old Apr 11, 2005 | 07:06 PM
camaro88sc's Avatar
Engine: 305 TBI
where would i be able to get the replacement heat shield?
Old Apr 11, 2005 | 07:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
On a replacement cat is the only place I've seen them available.
But, I still haven't seen everything...
Old Apr 11, 2005 | 07:16 PM
Car: 92 Z28
Goto summitracing.com and type in the following part#(THE-16500 )
Old Apr 11, 2005 | 07:40 PM
five7kid's Avatar
That's a fabric shield. I thought you were talking about a replacement type heat shield. It wouldn't go around the cat, but just on the floorpan above the cat.
It's also 44% the cost of a new direct-fit cat. Since the "original" cat is falling apart, at least on the outside, I think I'd opt for a new cat.
But, the fabric shield may work.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
