edelbrock tes owners come in
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
in the 2000-3000 rpm range while decelerating do any of your cars get real noisy .... I'm just curious if thats just what edelbrocks are like since these are my first and they are pretty noisy and I'm ready to go back to stock exhaust.
or do anyof you have any ideas to quiet them down I was thinking maybe header wrap around they Y pipe might help, maybe it's just there thin wall and wrap will help quiet it down.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Headers have thin walls compaired to the dense stock cast iron manifolds. They therefore do not dampen the sound nearly as well as the stockers. This is inherant of all headers. Changing mufflers and or adding a cat can greatly reduce overally exhaust 'loudness" though.
Header wrap won't do much for you and could become dangerous to use over time. Header compaies won't warrent their headers if heat wrap is used. Too much heat builds up and the headers can become damaged. They also soak in grease, grit and grime over time and could cause a really bad underhood fire.
Hotrodboba400
Dec 10, 2019 07:07 PM
sreZ28
Oct 22, 2015 08:21 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
