How much restriction comes from my tailpipes?
Old Apr 13, 2005 | 01:34 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I was just looking at my car and wondered since my tailpipes can't be more than 1.5" and there must be atleast 3 feet per side after it exits the single muffler. Does something like that make a difference?
Old Apr 13, 2005 | 05:15 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
The I-pipe will be more restricitve than the tailpipes themselves. You need to replace the whole cat-back to see any significant gains.
Old Apr 13, 2005 | 05:26 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
1.5" umm you better go measure. 2.25" and up is good.
Old Apr 13, 2005 | 05:58 PM
Car: 86 T/A
Engine: HSR 355
Yeah, just measured, 1 3/4".
I just had a new catback put in and plan on doing headers in the future. I'm just wondering if the tailpipes are restrictive enough to warrant a larger replacement.
Old Apr 13, 2005 | 06:32 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
yeah ah 1 3/4 tail pipes are def way to small. go with 2.25 ~ 2.5
Old Apr 13, 2005 | 07:23 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Don't bother changing the tail pipes. Two 1 3/4" tips have the same flow area as the stock 2.5" system (I am assuming 86 TPI cars were 2.5"). The whole system is a bottle neck but the tips are less restrictive than the I-pipe and muffler.
Old Apr 13, 2005 | 07:55 PM
Car: 86 T/A
Engine: HSR 355
What part is the I pipe? I have a flowmaster muffler on it right now.
Old Apr 13, 2005 | 07:59 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The I pipe is the long single pipe that runs along the undersie of the car. it connects your muffler to your cat. An aftermarket muffler is good but you see all your gains by going with a mandrel bent 3" pipe found in common cat-backs.
Old Apr 13, 2005 | 08:29 PM
Car: 86 T/A
Engine: HSR 355
Damn, I just had new 2.5" pipe put in. That'll be the next thing I do then when I have headers done. Thanks!
cheesehomer
Dec 31, 2015 08:48 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
BWilcox
Sep 20, 2015 12:19 PM
Stroopwafel
Sep 11, 2015 06:38 AM
