Flowmaster Cat Back
Old Apr 17, 2005 | 01:20 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Flowmaster Cat Back
Will the flowmaster 17133 from summit work for my car? I'm not worried about it not fitting to the cat, but otherwise, will it run where the stock piping runs?
Old Apr 17, 2005 | 08:23 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
That is for the 4th gen f-body, it can be made to fit, but I'm assuming your buying new? Then you should get 17233 flowmaster part number. Oh and the one you listed is only 2.5" pipe, while the 17233 Is 3".
Kevin
Old Apr 17, 2005 | 08:34 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
The 17133 is $85 cheaper so that's why I was looking at that one instead. In the product specs it says that it has a 3" intermidiate pipe going into dual 2.5" pipes, so does that mean the pipe is 3" from cat to muffler?
I also tried calling summit, but all they did was search the site, which is what I already have done. Then they just recommend the system that is made for my current factory setup.
Old Apr 19, 2005 | 09:43 PM
Engine: 383, L69
Yep sorry that was my fault i read the wrong one, it is 3 inch, and 85 bucks cheaper. I know over the axle pipe is the same except fo the mounting locations, i do not however know about the cat end of it. Maybe someone else can chime in on that.
Old Apr 20, 2005 | 11:12 AM
1bdbrd's Avatar
Car: 1991 Trans Am
have you thought about any other catback? the flowmaster wont be good for anything other than sound. there were numbers posted in the LS1 section on cz28.com a while back showing a 3 inch flowmaster catback flows worse than the stock 2.5 inch z28 cabtack...i would suggest a look at a better catback.
Old Apr 20, 2005 | 01:49 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
I can't find a better cat back for the price. Looking at Summit, the only cheap brands are dynamax, hooker, and flowmaster. Dynamax doesn't have 3" pipe. Hooker has ugly tips (i want 2 exit pipes, not 4). So, the only thing I'm left with is flowmaster.
Is there any other brand that offers a 3" catback that goes to 2.5" dual exit pipes and costs $250 or below?
Old Apr 20, 2005 | 02:52 PM
1bdbrd's Avatar
Car: 1991 Trans Am
personally if you want a cheap catback, just leave the stock one on there and get a piece of 3 inch pipe from the cat and get a cutout. then just connect it to the stock catback. that would be the cheaest and highest flowing one. if not i would save up some more and get a better catback. or even just make your own with a muffler and have an exhaust shop bend up some 3 inch pipe.
Vintageracer
Jan 10, 2020 05:33 PM
Navy8125
Aug 25, 2015 08:25 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
