New Headers...O2 sensor
Old Apr 19, 2005 | 03:24 PM
klumb15's Avatar
i got some new hedman hedders and i realize i need to put in a 02 sensor bung...but the thing is, come to think about it, i don't remember taking one out of my old headers....which wouldn't surprise me because it didn't have any kind of intake sensor or the right computer either...question is, should there be an o2 sensor in both headers? they are long tubes and i'm gonna be running duals with an h pipe...also where should i put the sensor/sensors....
Old Apr 19, 2005 | 09:37 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
There is only one in the driver side header, and you need to put it in the driver side collector, you can order O2 sensor bungs from jegs if you need it.
Kevin
Old Apr 19, 2005 | 09:51 PM
klumb15's Avatar
you think autozone or somebody locally sells the bung? beacsue the motor is going in this weekend...well i guess i can install it after the motor is in too....also, i hear guys talking about how you should put a heated sensor in if you have LT headers because otherwise it won't get hot enough and throw a false reading or something....anybody have any insight on this?
Old Apr 19, 2005 | 09:54 PM
Engine: 383, L69
No they wont have one, I tried that already, you can however get a non fouler for some kind of jeep, and cut the small end off and its the same thread size, you could try napa maybe.
Old Apr 19, 2005 | 10:02 PM
klumb15's Avatar
i'll look around..otherwise i'll just have to order a bung...but i should be fine with just a stock o2 sensor right??
Old Apr 19, 2005 | 10:04 PM
Engine: 383, L69
You should, but i think people switch over to the heated units because you can get better feed back from them when tuning, then again, i may be way off.
Old Apr 19, 2005 | 10:07 PM
klumb15's Avatar
yea that makes sense....anybody that has some more insight on this feel free to post....and if i should get a heated unit, let me know what one to get...
Old Apr 20, 2005 | 10:37 AM
pigsticker's Avatar
Car: 1992 z28
Engine: Vortec 350 TPI
Try this website. It might be helpful.http://www.jimsperformance.com/
I bought a wiring harness from him to make a heated o2 sensor work in a car that would normally use a non-heated sensor. He's got some good info on here,too. A lot of GM numbers charts and such. If you still have your single wire for your o2 sensor, he makes a wiring harness to convert over to a heated sensor. Easy to hook up, too.
Old Apr 20, 2005 | 12:20 PM
klumb15's Avatar
so i can just buy the the thing where it says heated o2 sensor for 75 bucks then buy the adapter for 20 bucks...thats a good deal then....thats all i gotta do to make it all work right?
Old Apr 20, 2005 | 07:09 PM
pigsticker's Avatar
Car: 1992 z28
Yes that's all you have to do to make it work, that is provided you still have your single wire plug. Easy to follow instructions, too.
Old Apr 20, 2005 | 07:28 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
So then what really is the advantage for installing a heated O2 sensor?
Old Apr 20, 2005 | 08:37 PM
klumb15's Avatar
because i have long tube headers for my car, and alot of people have problems with putting a stock o2 sensor in the collectors of LT's because they hardly reach the required temp which is i believe 600 degrees for the o2 sensor to just turn on...with a heated sensor, it'll become active a lot earlier and it'll give your computer a better feedback....i think thats what i'm gonna do tho, order those 2 items...i'll have to go look to make sure i still have the wire there for it...
Old May 8, 2005 | 09:39 AM
klumb15's Avatar
ok guys, i actually found my o2 sensor laying in a pile of crap....however, its not 3 wire like i thought, it is just a 1 wire...i looked at that website, they have a 1 wire o2 sensor for 35 bucks, but its not heated...what you guys suggest I do? i want to get a heated one so i can get better feedback, is there like a adapter kit to switch it from a 1 wire to 3 wire, or maybe a 1 wire heated o2 sensor and wiring harness??
Old May 8, 2005 | 10:13 AM
pigsticker's Avatar
Car: 1992 z28
Go to the above website in my previous post and click on "shop online" then click on TPI parts,Sensors, scroll down and you'll find the adapter wiring harness. It's the 5th item down for $19.95. Then you'll have to get a heated O2 sensor.
Old May 8, 2005 | 02:14 PM
klumb15's Avatar
ok...got it ordered...thanks for all the help...greatly appreciated...
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
