Oops!!
Oops!!
I have had my car since I was 16. I was dumb and bought a pair of cheapy flowtech longtube headers. I couldn't go over speed bumps or go through stupid dips in the road with out scraping. I am now much smarter and want a good pair of shorties, does anybody have a pair they want taken off their hands? If not which ones would you guys recomend? Thanks in advance
Transmission: 4L80E/4L80E
Hooker 2055, Edelbrock TES, Hedman 68491 (dual cat version) all are shorties with decent y-pipe.
What are you trying to support, engine-wise?
Its a fairly tame 305 for now, no funds=no mods, except the free ones
I already have a 3" cat exhaust without the cat hooked up to the longtubes that i want to keep but other than that no other mods so far, maybe performance chip, cam, heads when the moneys not so tight
I already have a 3" cat exhaust without the cat hooked up to the longtubes that i want to keep but other than that no other mods so far, maybe performance chip, cam, heads when the moneys not so tight Joined: Mar 2000
I went with the Hooker 2055's with a fairly healthily modified 305. Many have used them with a stock LG4. The consensus seems to be that the 2055 y-pipe is the best one out there for a single 3" cat.
If you go with TES, don't get the ones for the LG4 application. The EFE valve really restricts those poor things. The '86-'90 TPI single cat application version is much better.
If I was starting from scratch today, I think I'd go for the Hedmans.
All of these are in the $350-$400 range.
A dual snorkle air cleaner is also a good idea to help that poor engine breathe.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Hedman 68470 are good too, and are around $130 at Summit. I have a set, and I really like them.
It has TPI inducion right now so the dual snorkel is out of the question though i think it looks pretty sweet, btw any other mods you guys can think of that would help the old girl out? Lets also keep in mind i am a poor college guy LOL, so nothin too crazy
Okay, you didn't list year or induction, so I assumed a carb'd 305 (305 TPI isn't particularly lame, IMHO). Tunnel vision, I guess.
What year is the car?
www.summitracing.com . Type in "hok-2055hkr" in the search field at the top of the page. You'll soon see why I referred to them as an "investment".
If you used the '91 exhaust and it's single cat, replacing the exhaust will be a big boost to that powertrain. The single cat was only 2-1/4" diameter, major choke to any V8 engine.
After that, you're better off checking out the TPI and DYI PROM forums for other ideas to improve performance.
